Activity › Forums › RE:Vision Effects › Shot 23.97 fps with a 30 shutter speed: need to correct to look like more like film w/ RSMB
  • Shot 23.97 fps with a 30 shutter speed: need to correct to look like more like film w/ RSMB
    Posted by Pat Tremblay on February 25, 2016 at 2:25 am
    I Shot 23.97 fps footage with a 30 shutter speed (with a Canon 5D Mark 2):
    I realized I should have changed the speed so it would have better motion blur and look more like film.
    Any idea what would be the best formula with RSMB to achieve the needed result?
    Also, can I do this with shots that have already been rendered with additional grain, or it will smudge those too much?
    Thanks for any suggestion on this!
    HP Elitebook 8760w laptop. Windows 7 – 64 bit. Intel(R) Core (TM) i7-2820QM CPU @ 2.30GHz 2.30GHz, 8GB RAM – Quadro 3000M Nvidia graphic card.
    Pat Tremblay replied 10 years, 7 months ago 2 Members · 2 Replies
  • Peter Litwinowicz
    February 25, 2016 at 9:46 pm
    Gosh, it’s a matter of taste, isn’t it? However if you want to simulate 180 degree shutter and you had shot with a shutter that captured no blur, I would use 0.5. Since you already have some blur, shooting at 30 (degrees I assume), which is 1/6 of what you want (30/180), I would try (5/6)*0.5, or .416. Your mileage may vary.
    As to grain: adding motion blur after grain will smear the grain, as you have correctly anticipated. Again, that look may or may not be what you want
    Pete LItwinowicz
    RE:Vision Effects, In
  • Pat Tremblay
    February 26, 2016 at 8:42 pm
    Yeah, I guess the blur should be there at 30, BUT it might be an issue of some shots having been “accidentally” set differently for some reason, since they look strangely more video-y.
    Not sure how I can check the metadata on those files. rather curious to see if that was accident.
    Alright I’ll try that. Thanks for the answer!
