Activity › Forums › Adobe Premiere Pro › shorten a bunch of clips and batch encode them
Marc Nibor replied 11 years, 10 months ago 5 Members · 32 Replies
Marc Nibor
October 23, 2014 at 9:53 pmJosh, I just tried that. Bit it seems like this brings me bak to the point where I started from.
If I do that, AME encodes the full clips – not the new, short versions. That’s because I cannot seem to set the “source Range / clip in/out” I only can do that if I select one clip at a time. -
Josh Weiss
October 23, 2014 at 9:56 pmbut won’t the subclip ONLY have your selected range. i would think it would respect a subclip range.
Marc Nibor
October 23, 2014 at 9:58 pmhaha… I was actually googling PITA.
thought it might be a part of the solution ; ) -
Josh Weiss
October 23, 2014 at 10:00 pmso the subclipping fixed the issue? just worked in my tests here.
Marc Nibor
October 23, 2014 at 10:04 pmMaybe I’m doing it wrong, but the fact that it doesn’t was the reason I started this thread ; )
I thought this might be “fixed” in 8.1
Well, I’m a bit confused now… in case it worked for you before please let me know.
Josh Weiss
October 23, 2014 at 10:08 pmAre you sure you are making a SUB CLIP, hitting cmd-u and making a new clip out of it, and not just setting an in and out? i tested on 8.0. can test on 8.1 later if u can’t get it to work.
Marc Nibor
October 23, 2014 at 10:08 pm“in cc14.1 you could also use the consolidate transcode function to generate new media sets from the sequence timeline….just specify a destination…that should work.” >>>>>
I hope I’m not a PITA ; ) but could you please explain this a little further. I don’t exactly understand what I need to do.
Josh Weiss
October 23, 2014 at 10:24 pmGo to retooled.net blog entry about features in 2014.1. Ibc update.
Marc Nibor
October 23, 2014 at 10:26 pm“Are you sure you are making a SUB CLIP,….”
…actually I’m not!!! FINALLY seems to work.
It was exactly as you thought. It was totally my mistake.
Well, not totally because someone else (who won’t be named here 🙂 just taught it to me the wrong way.Thanks to everyone who helped!!
Alex Udell
October 24, 2014 at 12:34 am[Marc Nibor] “haha… I was actually googling PITA.
thought it might be a part of the solution ; )”THAT IS AWESOME!!!!! ROTFL
sorry about that!
Alex
