Activity › Forums › Adobe Premiere Pro › Shortcuts of the timeline window
Posted by Philippe Verdoni on March 21, 2011 at 4:17 pmFor an unnokwn reason some shortcuts of the Premiere CS5 timeline window do not operate anymore i.e:
Space bar key for Start/Stop; End and Beggining keys to move the CTI at the end or the beginning of the timeline.
There is apparently no way to define shortcuts for these commands in the Keyboard customization panel.
Thank you for your help.Philippe Verdoni replied 15 years, 6 months ago 3 Members · 6 Replies -
Todd Kopriva
March 22, 2011 at 6:01 am> There is apparently no way to define shortcuts for these commands in the Keyboard customization panel.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Philippe Verdoni
March 22, 2011 at 9:21 amAlthough these shortcuts cannot be defined, is there a Windows or Premiere CS5 file that could have been damaged?
Tim Kolb
March 22, 2011 at 2:22 pmYou have to click in the text field where the keyboard shortcut would be and type the key…
In the PPro CS5 help:
https://help.adobe.com/en_US/premierepro/cs/using/WS1c9bc5c2e465a58a91cf0b1038518aef7-7c2ea.html
Step 5 under “customize shortcuts”
TimK,
Director, Consultant
Kolb Productions, -
Philippe Verdoni
March 22, 2011 at 5:52 pmThe problem that I have is not how to define a shortcut but it is that in the Timeline window some options are unavailable such as:
Go to sequence end
Go to sequence start
Play/Stop -
Tim Kolb
March 23, 2011 at 2:50 am[Philippe Verdoni] “The problem that I have is not how to define a shortcut but it is that in the Timeline window some options are unavailable such as:
Go to sequence end
Play/Stop”…now I know I don’t understand the question.
in the list of keyboard shortcuts you’ll find:
“Go to Sequence-Clip End” shortcut: End
“Go to Sequence-Clip Start” shortcut: Home(These are applicable to the sequence or clip depending on what panel has the focus.)
“Play-Stop Toggle” shortcut: Spacebar (like all other NLEs I’ve ever laid eyes on…)
Is this really your question? I’m at a bit of a loss here…
TimK,
Kolb Productions, -
Philippe Verdoni
March 23, 2011 at 9:08 am-> Tim
You are right, these commands are in the “Help” section of the Keyboard Customization. Now I have reset everything. Thank you.
