Activity Forums Adobe After Effects shortcuts not working
  • shortcuts not working
    Posted by Jason Barczewski on June 24, 2010 at 1:34 pm
    i searched and can’t find the answer to how do i turn my keyboard shortcuts on in after effects cs5 settings.
    they don’t seem to be working.
    for instance, if i try to see keyframes of an effects on a layer and press the “u” key nothing happens.
    that is the case with several other shortcuts as well.
    using a dell natural keyboard pro which in english language
    how do i fix this?
    thanks
    Claudia Gabriela replied 13 years, 1 month ago 4 Members · 3 Replies
  • Todd Kopriva
    June 24, 2010 at 2:44 pm
    Are you sure that there are keyframes on the layer?
    What other keyboard shortcuts are you referring to?
    You don’t “turn on” keyboard shortcuts.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Kevin Camp
    June 24, 2010 at 3:02 pm
    try hitting ‘uu’ (2 u’s typed quickly). this will show all modified properties, including those with expressions, not just those with keyframes.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Claudia Gabriela
    July 25, 2013 at 7:53 pm
    Go to After Effects > Preferences > General… and the check off Use system shortcut keys. there IS a way to turn them on and off. :]
