Activity Forums Maxon Cinema 4D Shortcuts for Cameras > Perspective, Cameras > Parallel ?
  • Shortcuts for Cameras > Perspective, Cameras > Parallel ?
    Posted by Yoshiko Tanaka on August 6, 2014 at 8:43 am
    I just started using Cinema 4D R15 and I have some newbie question.
    I am doing basic modeling right now. In the process many times you end up moving your cameras around and I often need to reset to default. I saw in Greyscalegorilla tutorial that best way to do that is to go to “Cameras” and choose “Perspective” and “Parallel”. Is there any shortcut keys for these actions? Since I use then a lot I would really like to use keys instead of going to the menu every time.
    Yoshiko Tanaka replied 12 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 6, 2014 at 3:10 pm
    there is no default shortcut but you can give it one by going to Window/Customization/Customize Commands type ‘perspective’ into the Name Filter then select it from the list (it will be a list of one if you type enough of the name) then give it a shortcut – almost everything can be given a shortcut if it does not already have one, this is also a good way of finding shortcuts…
  • Yoshiko Tanaka
    August 6, 2014 at 4:03 pm
    You are right, just checked in the window and there is no default key. I’ll make one for my computer. Thank you for your answer!
    y
