Activity › Forums › Apple Final Cut Pro › shortcuts
  • Posted by James Ewart on August 22, 2012 at 4:11 pm
    For me the keyboard shortcuts for raising and lowering volume do not work…what do I need to do to make control + and control – work please
    Don Smith replied 14 years, 1 month ago 7 Members · 23 Replies
  • 23 Replies
  • Mark Dobson
    August 22, 2012 at 4:26 pm
    [James Ewart] “For me the keyboard shortcuts for raising and lowering volume do not work…what do I need to do to make control + and control – work please”
    Hi James – do you have a copy of Preference Manager if so have you – quit – trashed FCPX preferences and reopened?
    If not:
    https://www.digitalrebellion.com/prefman/
    Alternatively open commands and check you have the correct keyboard setup.
  • James Ewart
    August 22, 2012 at 4:51 pm
    Thanks for this…done both and no difference…must be something this end surely but cannot think what…trying to grab the audio bar in the timeline is hideously fiddly…seems to respond better if I first try and move it up with mouse and then drop it but nonetheless costing me a lot of time at the moment.
    Any other offers people?
  • Loren Risker
    August 22, 2012 at 5:57 pm
    Have you gotten it to work before? What kind of keyboard do you have?
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • Loren Risker
    August 22, 2012 at 6:26 pm
    Do other shortcuts using the control key work? Like controls-s to expand audio/video? Are you using the minus and plus keys on the number pad? Because they don’t work on a standard apple keyboard, I have to use the ones next to the delete key.
    I like this software because I can edit and organize much more quickly then I could in FCP7 or Premiere. But it took me a few months to get used to all the keyboard shortcuts and to develop organizational methods. I also mostly enjoy the way Motion works as a companion.
  • Bill Davis
    August 22, 2012 at 6:47 pm
    James.
    Try this. Open your System Preferences. Go to Keyboard and UN-Check “Use all f1, f2 keys as standard function keys.
    Close the panels and see if that helps.
    Seems to me that I had to do this back when I started using X in order to get all the keyboard combinations built into it to work properly.
    No guarantee, just a possibility.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • James Ewart
    August 22, 2012 at 6:56 pm
    thanks for your support…done the already…still sure I am being dumb but the most annoying feature so far (having got to grips with magnetic timelineO is inability to grab that audio bar without selecting clip…I was almost converted.
    thank you for feedback…very much appreciated
  • James Ewart
    August 22, 2012 at 6:59 pm
    nailed it..checked that box and now it works!!!!!!
    Thank you
    I owe you much beer!!
  • Bret Williams
    August 22, 2012 at 8:24 pm
    I used to have that audio problem too. It was hard to select. I’d always get the clip. But it NEVER happens anymore. I’d forgotten all about it. Either I learned what it wanted or 10.0.5 fixed it, or I quit trying to adjust audio with the clip so small. Now I use the tiniest filmstrip with audio view.
  • James Ewart
    August 23, 2012 at 11:45 am
    Thanks…I’m loving control, option S (expand all audio)!
  • Bret Williams
    August 24, 2012 at 4:42 pm
    I can’t find that command. That shortcut (ctrl+option+s) isn’t mapped to anything. There is a expand all audio/video. Is that what you’re talking about? Or ctrl+s which is expand audio video. But audio itself doesn’t expand as there’s no video associated with it. Expanding is a term that refers to expanding a combined video/audio clip.
    FWIW, I mapped shift+E to expand all audio/video clips. And mapped option+E to expand just audio/video with splits. I also mapped shift+cmd+E to collapse all clips.
    So, finally, now I can open it up with a shortcut, and then collapse it with a shortcut.
    Now they need to expand track (clip) size with a shortcut. Or at least make it mappable. I can’t see that anywhere.
Page 1 of 3
