Activity › Forums › Apple Final Cut Pro › Shortcuts
  • Jeremy Garchow
    October 13, 2014 at 3:07 pm
    Select the clip with c.
    Command-c. (copy)
    Option-v (paste connected).
    If not, then you hold option, click and drag the clip up.
  • Robin S. kurz
    October 13, 2014 at 3:42 pm
    [Jeremy Garchow] “hold option, click and drag the clip up.”
    Probably the easier/better option, yes. 😉
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • James Ewart
    October 13, 2014 at 5:12 pm
    I find option drag a bit tedious. Thus the OP. I guess I’m hard to please.
    Feature request “Duplicate as Connected clip”
  • Robin S. kurz
    October 13, 2014 at 5:25 pm
    [James Ewart] “I find option drag a bit tedious.”
    Uh-huh. Okay.
    [James Ewart] “Feature request “Duplicate as Connected clip””
    There’s always ⌘C and ⌥V.
  • Bret Williams
    October 15, 2014 at 12:34 am
    It’s definitely still annoying that you can’t combine option drag with shift to keep the duplicate from moving horizontally. Instead you have to rely on snapping or the visual +/- cue (which gives bizarre results sometimes dragging from a secondary. In FCP legacy I always held shift and the muscle memory won’t go away. If you hold shift it cancels the duplication.
  • Jeremy Garchow
    October 15, 2014 at 1:14 am
    Copy paste connected is my go to move.
  • Mark Morache
    October 15, 2014 at 1:31 am
    Likewise, I copy, and paste with option-v to add the connected clip.
    I just make sure I’m parked at the start of the clip I’m copying so the copy ends up in the same place, and not half way down.
    Doing the option-drag to make a copy, I like that I get a window giving me feedback of how much the clip is displaced, making it pretty easy to slide left or right until the window displays 0:00.
    I agree that adding the ability to press “shift” would make things easier.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
