Activity Forums Adobe After Effects Shortcut to Tool Launcher il_list Script
  • Shortcut to Tool Launcher il_list Script
    Posted by Sascha Koeth on May 5, 2019 at 3:18 pm
    Hi! Is there a way to create a keyboard shortcut to open tool launchers tl_list ? I tried to place it in the script folder to access it via the “ExecuteScriptMenuItem” shortcut command line but that doesn’t work as the tool launcher script only works in the ScriptUI panel Folder. Any idea? Thanks!
    HAYWOOD Digital Studio
    http://www.haywood.de
    Sascha Koeth replied 7 years, 4 months ago 1 Member · 1 Reply
  • Sascha Koeth
    May 7, 2019 at 10:57 am
    Found a first step to the solution:
    combine this shortcut modify approach:
    https://www.editingcorp.com/after-effects-scripts-keyboard-shortcuts/
    keep in mind the path has changed:
    /Users/username/Library/Preferences/Adobe/After Effects/16.1/aeks
    with
    this self-made script in the script folder:
    app.executeCommand(app.findMenuCommandId(“tl_list.jsxbin”));
    BUT!
    Does anyone has an idea on how to jump into the search field directly?
