Activity › Forums › Adobe Premiere Pro › shortcut to switching left and right channels
  • Alex Udell
    March 9, 2015 at 8:12 pm
    couple of questions
    Are you doing a swap or do you want one channel or the other?
    are you saying that you have different sources with different mappings?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Tom Adams
    March 9, 2015 at 8:19 pm
    i have recorded a question and answer session. main speaker on lav mic (left channel) and audience on external mic (right channel).
    looking for a shortcut to save me from making a cut at beginning and end of audience audio > doubling up the right channel > (so right channel fill both channels dual mono)
    over and over again for about twenty questions….
    sorry, hard to describe clearly…
    Regards,
    Tom Adams – Director/Owner
    Reelife Documentary Productions
    “cool digital video stuff…not boring or dumb”
    http://www.reelifeproductions.com
    Williamsburg, MA, USA
    http://www.FolktographybyTom.com
    https://Folktography.zenfolio.com
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
    Panasonic AGAC90, Canon D60 DSLR
  • Alex Udell
    March 9, 2015 at 8:56 pm
    search the effects panel for
    FILL LEFT and FILL RIGHT
    apply as needed to audio clips on your timeline…
    hth,
    Alex Udell
  • Jeff Pulera
    March 9, 2015 at 8:59 pm
    I do this with weddings to switch between shotgun and wireless. Use Razor and put a cut each time you want to switch. Apply “Fill Left” or “Fill Right” to each segment as desired. Drop “Audio Cross Dissolve” at cuts to blend and not get a “pop”.
    This effect fills either the Left or Right audio evenly to both channels of stereo track, and mutes other “channel” source.
    Make your own Custom effects folder, put these and other favorite effects in it and then they are right there to grab and apply, no searching.
    Jeff Pulera
    Safe Harbor Computers
  • Tom Adams
    March 9, 2015 at 9:07 pm
    Yes. Thank you!
    Regards,
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
  • Tom Adams
    Yes. Thank you!
    Regards,
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
  • Ken Conrad
    March 9, 2015 at 11:03 pm
    what i do for that issue is when the footage is in the bin, select: “modify > Audio Channels” from the right click menu and change them all to mono. (you can do all clips at once)
    Then when you bring them into the sequence they will be in separate tracks and you can do whatever you want with them.
    ken
  • Tom Adams
    March 29, 2015 at 9:30 pm
    yes! thanks
    Regards,
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
