Activity › Forums › Apple Final Cut Pro › Shortcut to replace *entire* clip with a PNG
  • Shortcut to replace *entire* clip with a PNG
    Posted by Xavier Paredes on November 1, 2019 at 4:50 pm
    Is there a shortcut that would allow me to replace a selected clip in the timeline with another clip (a PNG in my case) BUT fill the whole span of it? This is what I currently have:
    I simply want to replace the selected clip (i.e., what’s within the yellow range) with a PNG.
    The closest thing I was able to find is to hit “Q” but this adds the PNG above it. I want a shortcut to basically delete the exiting and replace it entirely.
    Any help is appreciated.
    Xavier
    Jeremy Garchow replied 6 years, 10 months ago 3 Members · 6 Replies
  • Eric Santiago
    November 1, 2019 at 5:37 pm
    D for Overwrite.
  • Xavier Paredes
    November 1, 2019 at 6:08 pm
    …but when I hit “D” it overwrites the portion of the clip that’s below it (2).
    I need it to overwrite the selected clip (1).
    Xavier
  • Eric Santiago
    November 1, 2019 at 7:21 pm
    I was wondering why you asked to replace the entire clip but show us the range.
  • Eric Santiago
    November 1, 2019 at 7:24 pm
    Should be Option + R.
  • Xavier Paredes
    November 1, 2019 at 7:37 pm
    Sorry. Maybe my screenshots were misleading.
    I tried “Option + R” but I got the “no can do” sound. But I figured it out!
    If the clip is selected it will work. HOWEVER, if the clip is marked as a range (X on the keyboard) it won’t work.
    Just clarifying for those who might be looking for the same functionality.
    Xavier
  • Jeremy Garchow
    November 4, 2019 at 10:07 pm
    That’s correct. Hit C and not X to select the clip, not the range of a clip.
