Activity Forums Adobe After Effects Shortcut to disable multiprocessing?
  • Shortcut to disable multiprocessing?
    Posted by David Cabestany on September 26, 2012 at 3:41 pm
    Besides Lloyd Alvarez’ Throttle and Purge script, which is not yet compatible with CS6, anyone else knows of a shortcut to disable multiprocessing without having to go to the preferences dialog?
    D.
    Paul Roper replied 13 years, 8 months ago 2 Members · 2 Replies
  • David Cabestany
    September 27, 2012 at 6:56 pm
    I got an email from him this morning, they will work on the CS6 update soon.
    The script has its own UI, which is dockable to the AE interface, so I can turn MP off without having to jump to different dialog windows that alone will save me a couple seconds each time, and trust me, I switch back and forth a lot.
    Anyway, as soon as it’s ready I’ll post the news here.
    Thanks Dave.
    D.
  • Paul Roper
    January 9, 2013 at 12:48 pm
    I came across that on aescripts.com and was disappointed to learn of its non-compatibility with CS6. I use Keyboard Maestro a lot, so made a macro for this (took all of 2 minutes to create) which I’ve assigned to a function key so I can just toggle multiprocessing on & off with a single keypress. It happens so fast I actually had to put a 0.5 second delay in there to give me enough time to see the check mark appear/disappear from the prefs dialog box.
    After Effects is pretty good normally when it comes to keyboard shortcuts – it has almost all my commonly used things “shortcutted”. But other apps such as Final Cut are not so shortcut-friendly so I have quite a few Keyboard Maestro macros to speed those up. Not that that’s relevant in an AE forum!
