Activity Forums Adobe After Effects shortcut: making frames from video clip
  • shortcut: making frames from video clip
    Posted by Nils Palmen on December 17, 2005 at 12:00 pm
    hi,
    is there a way to push 1 button so that a video clip of 20 seconds get’s divided in all of it’s frames – seperately? … or do i need to save them one by one?
    tnx
    Nils Palmen replied 20 years, 9 months ago 3 Members · 13 Replies
  • 13 Replies
  • Lessevolvedman
    December 17, 2005 at 12:06 pm
    Why don’t you set up to render as an image sequence of your choice in the render output module??
  • Lessevolvedman
    December 17, 2005 at 12:09 pm
    or maybe i missread ur question and u wish to do this within AE, without having to render out as images then reimport…if so then my bad, cant help u out there..
  • Nils Palmen
    December 17, 2005 at 12:24 pm
    yes, maybe i diodn’t explain myself fully … i wanna make a camera fly through … it needs to fly through diffrent layers … every one of this layers – is 1 frame of an actual avi. file that i made … so that’s what i need to know … if there is a simple trick to render a avi. clips seperate frames … so i have 20 seconds x 25 frames/sec = 500 still images … i wanna put these stills in 3d space – in a row – and fly through – so we get an animation with more depth – (at least i hope to make more depth)
    so – the button the gives you all the frames from a video file … withouth having to render them all out one by one …
  • Nils Palmen
    December 17, 2005 at 12:31 pm
    yeah, okay – render output module … format: tiff sequence … this one worked – only problem is that it renders them out in 4/3 format instead of the 16/9 i have my project in … anyone know why this happens? is TIFF sequnece the best one or you think another is better – jpeg for instance … btw lessevolvedman – i’m an even lesserevolvedermanner 😉 …
  • Filip Vandueren
    December 17, 2005 at 12:47 pm
    You could give the layer time-remapping,
    give the time an expression like this:
    startIndex=1;
    thisComp.frameDuration*(index-startIndex)
    You can also give the position an expression like:
    startIndex=1;
    position+ [0,0,100]*(index-startIndex)
    to spread all the layers 100 pixels apart in Z-depth.
    You should change the value of startIndex to the layer-number of your first video-layer.
    So, if for example: your camera is layer 1, your lights layers 2-4, and you have some text on layer 5, you should change the value to 6 since the first video-layer is N
  • Filip Vandueren
    December 17, 2005 at 12:50 pm
    About you’re previous post: the 16:9 is probably just a matter of adjusting “interpret footage” your stills.
  • Lessevolvedman
    December 17, 2005 at 12:52 pm
    interpret footage should be your prob with the images not looking 4/3
  • Lessevolvedman
    December 17, 2005 at 12:53 pm
    bah…filip beat me
  • Nils Palmen
    December 17, 2005 at 4:20 pm
    yes okay – tnx for the expression tips …
    i can imagin that this would be a pain to render .. i’m fairly new to AE so scripts and all that jazz sounds like countreymusic in my ears … . not familiar i mean.
    but maybe i could cut of all the layers that iv’e fly throuh … so the computer will not have to render those anymore because i don’t use them anymore – and maybe there is a certain visibility happening – like the screen only shows layers 1-20 (or 50-70 and so on) … so would it help if i HIDE the other layers that arn’t needed (with an experession or something – (or maybe give them weak resolution) … so my rendering will be faster … . and the pc needs only 20 layers rendering at a time? … does it work this way? or will he compute them al anyway?
    tnx guys, it’s helping…
  • Filip Vandueren
    December 17, 2005 at 4:44 pm
    Yeah Nils,
    I was thinking about it a little more and came to the same conclusion…
    Depending on how you place the layers you fly through in 3D, there could be as little as 2 layers needed/ visible at one time…
    With some clever expression fumbling, the layers that are no longer visible could jump from behind the camera that passed them, to a new position behind the next layer, and also update their time-remapping so they now show the correct frame, in time before they become visible…
    If that makes any sense. 😎
    I did something like that once to create a quasi-infinite floor using about 4 large layers.
    If you can draw a sketch or post an example project using solids, that shows how you want to move the cam, I could figure out the expressions for you.
