Activity › Forums › Apple Final Cut Pro Legacy › shortcut keys for add keyframes to first and last frame of clip
  • Tom Wolsky
    March 26, 2009 at 1:44 am
    I answered this already.
    x
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Kevin Monahan
    March 26, 2009 at 2:10 am
    No automatic way for first and last keyframes at the same time but you can press CNTRL + K then down arrow then press CNTRL + K once more.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Carsten Orlt
    March 26, 2009 at 2:36 am
    or get Spark (https://www.shadowlab.org/Software/spark.php)
    don’t worry about the beta stage as the software works flawlessly.
    there are other shortcut manager software but this is for free and has a super small foot print.
    endless possibilities for everything that is not on one button.
    and you can use it for any other software you have 🙂
    Carsten
  • Victor Perez
    March 26, 2009 at 5:10 pm
    Try this
    Un-select X
    Highlight your first clip you want to keyframe.
    Set start end keyframes on that clip DO NOT adjust them, just set them.
    Copy Attributes of that clip.
    Highlight all other clips you want start and end keyframes on.
    Paste attributes making sure that SCALE ATTRIBUTE TIMES is selected. This keeps the keyframes scaled to each clip, meaning that a long clip will have keyframes set at its beginning and end and a short clip will have its keyframes SCALED down to its beginning and end.
    Now all clips have start and end keyframes and all you have to do is adjust each clips keyframe accordingly.
    good luck
    Victor
  • Hannah Neufeld
    March 26, 2009 at 6:57 pm
    Thanks so much for all of your help.
    CtrlK is the command that I was trying to remember and I will give the paste attributes option a try as well.
    You’ve saved me hours of clicking – Cheers!
  • Abi Mcneil
    June 17, 2012 at 1:01 pm
    For some reason ctrl K isn’t working on my program. I’m using FCP7 and I haven’t customized any keyboard shortcuts – any ideas?
