Activity Forums Adobe Premiere Pro Shortcut keys change between sequences in the same project
  • Shortcut keys change between sequences in the same project
    Posted by Brad Coulter on June 6, 2017 at 2:32 pm
    Is there a setting that would cause default shortcut keys to change from one sequence to another?
    I use the next edit point and previous edit point (down and up arrows) a lot. I’ve noticed that in some sequences the up arrow seems to go to the home key (beginning of sequence) and the down arrow does nothing at all. In other sequences, everything works as expected.
    What did I screw up? 😉
    Brad Coulter replied 9 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
