Activity Forums Avid Media Composer Shortcut for ‘go to next clip’ in Source / Record monitor?
  • Shortcut for ‘go to next clip’ in Source / Record monitor?
    Posted by Brad Kimbrough on May 7, 2015 at 7:42 pm
    I’m drawing a blank here. Is there a keyboard shortcut to ‘go to the next clip’ in the Source / Record monitor? As in, I have 2+ clips / sequences loaded and want to toggle between them, within the ‘Clip Name Menu’.
    (This is different, of course, from the Esc key, which just toggles between the Source / Record sides.)
    Thank you!
    Brad
    Shane Ross replied 11 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    May 7, 2015 at 9:12 pm
    The name of that is FAST FORWARD, and REWIND. And you can map them to wherever you want to. I put them on the UP and DOWN arrows, like they are in FCP 7.
    Then, in the COMPOSER SETTINGS, in the FF/RW tab, you can have it ignore track selectors, stop at head frames…and the like.
    Shane
    Little Frog Post
