Activity › Forums › Adobe After Effects › Shortcut for bringing footage into the timeline
  • Shortcut for bringing footage into the timeline
    Posted by Antonia Gogin on April 28, 2007 at 10:57 am
    Hello,
    Can someone tell me what the short cut is for bringing multiple clips from the project window in a consequetive order one after the other into the timeline. Would be greatly appreciated! Thanks!
    Antonia Gogin replied 19 years, 5 months ago 2 Members · 2 Replies
  • Erik Pontius
    April 28, 2007 at 9:39 pm
    Not sure if there is a short cut straight out of the project window. However, you can select the layers in the project bin in the order you want drag them to the comp, then select all the layers and choose “Animation > Keyframe Assistant> Sequence Layers” and then choose your options for overlap if desired. This will put the layers end to end.
    Erik
  • Antonia Gogin
    April 29, 2007 at 4:47 pm
    Hey,
    Thanks! That works great….was exactly what I was looking for.
