Activity Forums VEGAS Pro Shorcut for a fade
  • Shorcut for a fade
    Posted by Mynor De león on October 31, 2011 at 11:15 pm
    Hi there, I work a lot with power point slides (JPEG files at the end) and Im wondering if there is or if we are able to create a shortcut to have the same fade in a selected piece.
    For example, 15 o 20 frames just by doing CTRL + (something.
    Mynor
    Mynor De león replied 14 years, 9 months ago 3 Members · 5 Replies
  • Dave Lozinski
    November 12, 2011 at 3:37 pm
    I don’t believe so, but maybe one of the experts on here can lend some insight.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
  • Mike Kujbida
    November 12, 2011 at 6:12 pm
    Do you want the slide to have a 15 frame fade in, a 15 frame fade out, both or is this a crossfade from slide to slide?
  • Mynor De león
    November 14, 2011 at 7:45 pm
    Hey, thanks for the interest… the idea is 15 fade in and 15 fade out. Thanks!!
  • Mike Kujbida
    November 14, 2011 at 8:23 pm
    As long as you’re running Vegas Pro and not one of the Movie Studio versions, John Rofrano posted a script called FadeEventInOut.js in the Fade in/out video event question thread that will do what you want.
    To make it 15 frames instead of 30, change 1000 to 500 in the line var fadeAmount : Timecode = new Timecode(1000) and re-save it under a new name (e.g. FadeEventInOut-1-2_sec.js).
    I keep two versions of this script (1/2 sec. and one sec.) on my toolbar as I use it a lot.
  • Mynor De león
    November 14, 2011 at 9:04 pm
    is exactly what I was searching´ for, THANKS a LOT
    Greetings from Guatemala.
