Ty Ford
August 18, 2016 at 12:38 pmHello Hemant,
No, I am not. Those mics I mentioned are all good lavs, but there’s no mention in the Olympus 11 config about bias voltage or phantom power requirements.
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford\’s Blog -
Hemant Agarwal
August 18, 2016 at 7:23 pmHey Ty..The Olympus Ls-11 similar to pcm-m10 gives out 3v bias voltage via a 3.5mm ..
It does not give out phantom power..Do you think that my ecm-77 and ecm-44 will work fine with it ? I presently use these lavs with an Audio Technica U100 transmitter receiver ( https://www.audio-technica.com/cms/wls_systems/343f7d7ae3a806e6/ )
Do you think that if I connect one of these lavs to the Olympus ls-11 after replacing the TA5f connector with a 3.5mm one, then it will work fine ?
Ty Ford
August 18, 2016 at 9:31 pmHow about the Audio Technica MT830c?
I ran it with the U100 series here. I had eric Toline make me a small adapter cable for my Sennheiser G2/G3 wireless.
TA5F to 1/8″
No problem.
You can find him at……audioetc@bellsouth.net
Regards,
Ty Ford
