Activity › Forums › Panasonic Cameras › Shooting in UK/Germany
Posted by Peter Mackay on May 18, 2011 at 3:58 pmIn a few weeks I will be traveling to Europe to shoot interviews for a corporate piece. I need to know what to change in my HVX200 settings to prevent flicker from the 50hz electrical supply. I need to be shooting at 30pn.
Thanks for any tips.Robin Probyn replied 15 years, 4 months ago 6 Members · 8 Replies -
Philip Merten
May 18, 2011 at 4:56 pmIf your shooting in fluorescent light set your shutter at 50 and that should get rid of the flicker..
Peter Mackay
May 18, 2011 at 5:03 pmReducing the shutter from 180 to 50 will result in not being able to shoot in available light and will also cause strobing due to the narrow shutter. Is this the only solution?
Philip Merten
May 18, 2011 at 5:10 pmIf you shoot it in PAL that would also solve the flicker problem but probably create new issues at the same time. Anytime that I’ve gone to a country that uses 220V current I always set my shutter to 50 in fluorescent lighting situations and that’s solved the problem..
Chris Tompkins
May 18, 2011 at 5:22 pmDo you only have to worry about it for the flo’s?
Chris Tompkins
Video Atlanta LLC -
Noah Kadner
May 18, 2011 at 6:53 pmAlso sodium vapor lamps. Personally I’ve found this to be massive PITA when going into PAL/50 countries such that I’ve switched to renting gear locally to get around it. Problem is unless you’re working with a decent sized monitor you will miss the flickering more often than not while shooting. And it’s pretty much impossible to get out in post.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
Dan Brockett
May 19, 2011 at 12:11 amI did a shoot in Denmark with my HPX170 and a shoot in France with my 5D MKII. In both cases, 1/50th of a second shutter removed all ballasted lamp flicker issues, the video looked great.
Dan
A Producer Who Is Also A DP? Yep, that’s Me.
Peter Mackay
May 19, 2011 at 1:17 amThanks for all the replys guys, I got it now. I had assumed the first poster had suggested changing the shutter angle from 180deg to 50 deg. So I will go with the 1/50sec exposure.
Robin Probyn
May 19, 2011 at 5:16 amyou will also need 240v UK and 220v Germany bulbs for your lights..
