Activity › Forums › Panasonic Cameras › Shooting in Europe at 24p, need to eliminate flicker
Posted by Brooks Moore on August 18, 2007 at 7:17 pmI am shooting in Spain at 24p with an HDX900. I need to eliminate the flicker from the lights.
ThanksJason Starr replied 19 years ago 6 Members · 12 Replies -
Mariusz Cichon
August 19, 2007 at 3:19 pmor 172.8 degrees shutter, same exposure time just different value that you can see in vf
Brooks Moore
August 19, 2007 at 10:01 pmHow do you set the shutter to 172.8 degrees on the HDX900.
Thanks -
Robin Probyn
August 19, 2007 at 11:32 pmSet to the half setting with the shutter switch on the front on the camera .At 24p this will give you 1/48 = 172.8.This is a great feature on the HDX900,you dont have to work it out in your head !
I dont think the HDX900 displays shutter as angles only fractions of seconds,anytime I,ve used it anyway but not 100% sure.?? even in film mode. -
Robin Probyn
August 21, 2007 at 10:34 pmOk thanks.That half setting is really a good idea,esp for people like me who cant get it right!
Robin Probyn
August 21, 2007 at 10:40 pmSo if shooting 23.98p in NTSC country 1/48th is correct for flicker?
thanks
Steve Mahrer
August 22, 2007 at 4:46 pmRed Flag;
No, not if you’re worried about 60Hz lighting flicker. If you’re shooting 23.98 in the US and want to elimitate 60Hz lighting flicker you shoudl use a 144 degree shutter. The math is easy 60 / 24 = 2.5 So 360 degrees with 2.5 = 144 degrees, the correct shutter angle to freeze lighting modulation.
Cheers!
Steve Mahrer – Panasonic Broadcast
Robin Probyn
August 23, 2007 at 12:34 pmok thanks.But what is that in fractions of a second?
Thanks again
Steve Mahrer
August 23, 2007 at 6:52 pmRe: “ok thanks.But what is that in fractions of a second?”
144 deg shutter in 23.976p equals 1/60th second (AC power freq)
Cheers!
