Activity Forums Sony Cameras Shooting green screen
  • Shooting green screen
    Posted by Nitin Kulkarni on December 6, 2012 at 9:19 am
    hi,
    i want to shoot highly professional green screen video. i am confused between shooting on Canon 5D Mark iii and sony pmw 500 Xdcam hd 422. i want to use 5D but am not sure about its recording format. with H.264 and 4:2:0 will be able to pull of better key? or should i go with sony 500 whhic records 4:2:2 for the best results?
    nitin
    Michael Palmer replied 13 years, 9 months ago 4 Members · 3 Replies
  • David Wheeler
    December 6, 2012 at 3:26 pm
    The 4.2.2 color space will always give you a better key. Of course, a 4.2.2 color space will not solve problems with lighting, reflections, etc., but if you set up everything else right, 4.2.2 is better than 4.2.0.
    David Wheeler
    EX1R; EX3; nanoFLASH; FCP 7; 17″ MBP, MacPro Quad, Matrox MSO2,CS5
    dave@marcombiz.com
  • Greg Ondera
    December 6, 2012 at 3:50 pm
    4:2:2 always, but if you use the other, make sure you use a light magenta gel on your strike light for better separation, especially with gray hair.
    Greg Ondera
    http://www.Plexus.tv
    http://www.SurgeonToday.org
  • Michael Palmer
    December 6, 2012 at 4:26 pm
    If you’re renting a camera you will want to choose one with SDI (or certain cameras with HDMI) and rent either a Nano Flash or KiPro Mini to record to, as this will allow you to go beyond the internal recoding limits of the camera. 4:2:2 at or above 100 Mbps is a good file for green screen.
    It sounds like you want to use a single chip camera, I would choose either the Sony FS100/700 or the Sony PMW-F3 and together with and external recorder you will have very professional green screen video files.
    If you are purchasing a camera then hands down go with a professional camera like the 500.
    Good Luck
    Michael Palmer
