Activity › Forums › VEGAS Pro › Shooting for Instagram ratio
  • Shooting for Instagram ratio
    Posted by Rob Lindsay on December 17, 2018 at 11:14 pm
    I have been shooting a project with my DSLR held vertically for full frame quality for an Instagram client. I have not been able to get Vegas to accept it as a vertical frame — it has the black top and bottom and it’s still on it’s side. When I use Video FX pan, it makes it smaller, loosing the advantage of all the pixels i started with.
    I tried setting it up in the initial dialog box , checking the “rotate counterclockwise” box, b ut it has had no effect. is there a way to get the full frame vertically into the timeline?
    Many thanks!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
    Rob Lindsay replied 7 years, 9 months ago 2 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    December 18, 2018 at 4:41 am
    [Rob Lindsay] “I tried setting it up in the initial dialog box , checking the “rotate counterclockwise” box, b ut it has had no effect.”
    Hi Rob – Just to clarify/confirm, are you doing this is in Project Settings?
    * Grazie
  • Rob Lindsay
    December 18, 2018 at 6:13 am
    yes, Graham — in project whereI can rotate 90 degrees, but it doesnt translate to the timeline that way.
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Graham Bernard
    December 18, 2018 at 6:55 am
    [Rob Lindsay] “in project whereI can rotate 90 degrees,”
    Erm….. Rob, please show us your PROJECT SETTINGS Screen.
    * Grazie
  • Rob Lindsay
    December 18, 2018 at 3:18 pm
    Sorry here is the Project box
    Vegas is not rotating the image as spec’d in the box. Rather it is letterboxing it. I want the entire image rotated to vertical if possible without the black bars.
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Graham Bernard
    December 18, 2018 at 3:40 pm
    [Rob Lindsay] “Vegas is not rotating the image as spec’d in the box.”
    Now rotate the Media.
    * Grazie
  • Rob Lindsay
    December 18, 2018 at 5:43 pm
    It isn’t rotating. What am I missing?
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Rob Lindsay
    December 18, 2018 at 5:48 pm
    OK found it in the help menu, of all places.
    thanks, Graham!T
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Graham Bernard
    December 18, 2018 at 6:32 pm
    [Rob Lindsay] “thanks, Graham!T”
    Rob, you’re welcome. But I’m not sure how I helped?
    * Grazie
  • Rob Lindsay
    December 21, 2018 at 8:15 pm
    You let me know it could be done, which I wasn’t sure of.
    Thanks again!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
