Activity › Forums › Panasonic Cameras › Shooting and Importing very long clips, Spanned/Incomplete
Jeremy Garchow replied 17 years, 5 months ago 4 Members · 13 Replies
Dave Neyman
September 2, 2008 at 5:12 amThe P2 cards are actually made of of separate 4GB drive connected by a mini raid controller in the card. The 16 GB is 4 drives and the 32 GB is 8. They will show up as separate clips that span across different drives until they are all loaded in to the log and transfer window in FCP at which point they are reconnected. Hope that makes sense.
Noe Sardet
April 6, 2009 at 3:58 pmHello,
I have had similar problems importing MXF files into FCP with Calibrated(MXF). But in my case I don’t have long clips. They are all under 4Go. When I import them, the files are truncated, incomplete.
My hard drive is Fat32. By transferring the files to another disk, which is formated Mac OS Extended should it solve the problem?
Thanks -
Jeremy Garchow
April 6, 2009 at 4:32 pmI don’t know. It sounds like you should contact Calibrated about it.
Jeremy
