Activity Forums Apple Final Cut Pro Legacy Shooting a wedding using AVCHD & Z1
  • Shooting a wedding using AVCHD & Z1
    Posted by James Bishop on June 5, 2010 at 3:33 pm
    I am shooting a wedding in a couple of weeks, where I plan on using three cameras. Two cameras are HDD cameras (sony sr55e) which record AVCHD files, and one Sony Z1.
    I was wondering if anyone could give me some advice as to how easy it will be to do multi camera editing, using both AVCHD and DV files.
    James 🙂
    Tom Wolsky replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Zane Barker
    June 5, 2010 at 3:37 pm
    Multicam requires everything to be the same codec, frame size and frame rate. So you will need to convert everything to match.
    Also why would you shoot DV with the Z1 when the camera can shoot HDV and your other cameras also shoot HD?
    Hindsight is always 1080p
  • James Bishop
    June 5, 2010 at 3:43 pm
    Yes sorry I meant to say HDV
    Will it be fairly simple to convert the files from my HDD cameras, to the same codec etc as the HDV files?
    Thanks for the response
  • Tom Wolsky
    June 5, 2010 at 4:25 pm
    The AVCHD files convert to ProRes on ingest by default. The HDV material can be ProRes as well, so it shouldn’t be a problem. Just make sure the AVCHD cameras shoot in the 1440x1080i settings and not in full 1920×1080. That way they will match the HDV camera’s aspect ratio.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • James Bishop
    June 6, 2010 at 5:52 pm
    Thanks Tom. Unfortunately it doesn’t seem you can alter those settings on my AVCHD camera so I guess the only way to do it will be to slightly squash the footage..
    James 🙂
  • Tom Wolsky
    June 6, 2010 at 9:24 pm
    You’ve got a bit of problem. The SR55E does not appear to be an AVCHD or any kind of HD camera. According to Sony tech specs it’s a standard definition camera
    https://www.sony.co.uk/product/sdh-hard-disk-drive/dcr-sr55e
    All the best,
    Tom
  • James Bishop
    June 8, 2010 at 1:39 pm
    Hi Tom.
    Sorry, I made a mistake and put an extra ‘5’
    its a sony HDR-SR5E
    James 🙂
  • Tom Wolsky
    June 8, 2010 at 3:47 pm
    Then you’ll have to convert the media to match. I’d suggest you check the camera manual carefully as some of the more compressed formats might be in 1440×1080.
    All the best,
    Tom
