Activity › Forums › Corporate Video › Shooting a subject next to LCD monitor
  • Shooting a subject next to LCD monitor
    Posted by Chris Babbitt on May 17, 2008 at 6:02 pm
    Yesterday, I had to shoot a talking head seated next to an NTSC monitor which was either LCD or Plasma. He was running a PP presentation of his laptop through the DVI input. My problem was with color temperature. I had the subject lit @ 3200k, but the color temperature of the monitor was off the scale…over 10,000k. I don’t recall having this problem before, when it was a CRT monitor. I think even if I lit with HMIs, the monitor would still be blue. Is there a recommended procedure for this?
    Jb Letchinger replied 18 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Bill Davis
    May 18, 2008 at 8:45 am
    Rosco and Lee both make gels that combine CTO (color temperature orange) with up to 2 stops of ND (neutral density) in rolls.
    Cut one or two sheets to fit the LCD or Plasma where it will hold in place nicely via static cling.
    Yeah, the full rolls are expensive. But one will last your entire career.
    Good luck.
  • Mark Suszko
    May 19, 2008 at 4:21 pm
    Did you try adjusting the colors on the display? Deliberately throwing it off to the eye but making it look right to the camera? If there is a live studio audience this will be a problem, but if you are in the studio alone with the talent, only what the camera actually sees matters.
  • Chris Babbitt
    May 19, 2008 at 4:50 pm
    There was a white balance adjustment on the monitor, but it was very limited. I had it set to the warmest setting available.
  • Mark Suszko
    May 19, 2008 at 5:08 pm
    See, I don’t know what you do when its an HDMI source, but we’re still analog over here and the answer in that case, when you don’t have the lights or gels to match it, would be to run the monitor’s signal thru a proc-amp and time base corrector, use the procamp to jigger the colors around until they looked “right” to the camera.
    There was an old practical joke they used to tell stories about. The original source is lost to me, I want to say it was somewhere in New York. Two teams of engineers were trying to match color on remotely located cameras, and instead of color bars, or a live person’s face (takes too long under hot lights of the time) they used a bowl of fruit.
    Some wag paints the bannana blue or red or green, can’t recall which now… engineer at the other end just about stabs himself in the eye with his “greenie” because whatever he does to make the bannana look correct, it throws everything else in the fruit bowl into crazy colors.
    If you’re feeling naughty, you can do the same thing to somebody with color bars and photoshop these days.
  • Timothy J. allen
    May 19, 2008 at 9:41 pm
    Now, that’s just plain mean, Mark.
    (shaking head)
  • Mark Suszko
    May 20, 2008 at 3:15 am
    Hope nobody did that to the camera calibration targets on the Phoenix:-)
  • Timothy J. allen
    May 20, 2008 at 2:21 pm
    Guess we’ll find out on Sunday.
    There’s no “fix it in post” for that shoot. 😉
  • Jb Letchinger
    June 20, 2008 at 11:31 pm
    I’ve shot with alot of different monitors and find that I almost always have to warm the monitor settings up, and add blue to the lights. There may be color balance/color temperature/white point setting in the monitor menu that’s buried under advanced settings… its doubtful that the monitor is over 10,000K – usually the settings are 4500K – 9500K – and that’s with an adjustable white point.
    Gels on the monitor, I personally wouldn’t do – usually too much hassle, time, reflection, preciseness of the cut, etc… The remote is your friend, but don’t forget the CTBs in your light kit: Full, Half, and Quarter!
    Better luck next time.
    JB
    <https://www.jblfilmsinc.com>JBL Films, Inc.
    please vist
    <https://www.jblfilmsinc.com>https://www.jblfilmsinc.com
