Activity › Forums › Canon Cameras › Shooting a computer screen with a Vixia hf r20
Posted by Randy Champion on March 7, 2012 at 6:38 pmWhat is the best setting to eliminate the “rolling” effect when I shoot a computer screen?
Todd Terry replied 14 years, 6 months ago 2 Members · 1 Reply -
1 Reply
Todd Terry
March 7, 2012 at 7:08 pmThe best solution is to shoot with a camera that has a “clearscan” mode, that allows you to dial in the exact shutter speed needed to eliminate the rolling. Here in the US, the clearscan shutter speed setting is usually 1/60.1 (for 60.1Hz power).
If your camera won’t clearscan but you can choose other standard shutter speeds, try one a little lower.
Or another (less satisfactory) option is to play around with the refresh rates on the computer. On a windows PC, that would be going START > SETTINGS > CONTROL PANEL > DISPLAY > SETTINGS > ADVANCED > MONITOR… where you will see a dropdown box that will allow you to try different refresh rates. You may find one that eliminates (or at least lessens) the rolling. Just remember to put the computer back as it was once the shoot is done.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
