Activity Forums Panasonic Cameras Shooting 60fps, editing 24
  • Shooting 60fps, editing 24
    Posted by Kerry Mcdowall on January 16, 2007 at 7:41 pm
    We are editing in Final Cut Pro 5.1.2, and normally shooting DVCPRO HD in 60i on the panasonic AJ-HDX900. Our normal route is to import>Panasonic P2 and it comes in as 29.97. We then use the reverse telecine from Cinema Tools to bring it back to 24 for editing. What is our route when we crank the camera to 60fps? Cinema tools doesn’t like it. Final cut pro doesn’t like it. There isn’t an import option of 1080/60p. We obviously shot it this way to create slo-mo…I read that perhaps we need to download a file from panasonic, but that was referring to an older model of camera.
    We’re at a bit of a loss here when shooting varispeed. Any help would be appreciated!
    Kerry
    Frank Nolan replied 19 years, 8 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    January 16, 2007 at 10:09 pm
    Are you sure you are shooting 1080? Over and under cranking is usually done in 720p.
    Jeremy
  • Gary Adcock
    January 16, 2007 at 11:46 pm
    [Kerrymcd] “We’re at a bit of a loss here when shooting varispeed. Any help would be appreciated!”
    Sorry
    the HDX 900 cannot do variable speed captures, Panasonic cameras only support variable frame rate acquisition in the Varicam and HVX200 models. In both camera models VFR is only on 720p content,
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Frank Nolan
    January 17, 2007 at 6:30 am
    [Kerrymcd] “We are editing in Final Cut Pro 5.1.2, and normally shooting DVCPRO HD in 60i on the panasonic AJ-HDX900. Our normal route is to import>Panasonic P2 and it comes in as 29.97”
    How are you using the import P2 feature when the HDX900 is a tape based (not P2) DVCPRO HD camera?
