Activity › Forums › Sony Cameras › shooting 50i in the US/Canada?
Posted by Sam Cole on December 14, 2010 at 11:47 pmWe are about to start shooting a doco using international crews.
Is there a problem shooting 50i in the US/Canada region under lights ie 10hz flicker?
Its been a while since we have done this (in SD) and I know it was a problem way back then.Sam Cole
On line Mastering Facility
FCP, Avid, Adobe
Sydney, AustraliaRafael Amador replied 15 years, 4 months ago 3 Members · 5 Replies -
John Sharaf
December 14, 2010 at 11:57 pmHi Sam,
Well yes, it’s exactly the same phenomenon in SD and HD, you’ll need to adjust your shutter to eliminate flicker from the 60 hz lighting you’ll encounter with fluorescents, neons and magnetic HMI’s running on US power.
The magic shutter angle is 150° (1/25 s. x 150/360 = 1/60 s.).
JS
Rafael Amador
December 15, 2010 at 6:45 pmJohn’s formula should works mathematically.
You can also try the built-in anti-flicker filter (50Hz/60Hz/Auto).
As long as a flicker remains constant, should be possible to be avoided.
I have many problems with flicker when powering from generators or small grids on the country side.
rafael -
Sam Cole
December 16, 2010 at 12:29 amThanks guys for your thoughts.
The other thing I was considering was shooting ‘natively’ and doing a mixed format edit in FCP.
Are there many pitfalls in having 50i and 60i media on the same timeline?Sam Cole
FCP, Avid, Adobe
Sydney, Australia -
Rafael Amador
December 16, 2010 at 5:22 pm[Sam Cole] “Are there many pitfalls in having 50i and 60i media on the same timeline?”
You can mix stuff with different size, pixels, codecs or field-order, without problem.but were FC doesn’t shine at all, is when mixing different time-base stuff.
The results will depend very much of the nature of the picture, but, if you put i60 on a i50 sequence, will look choppy: 10 Pictures have to be dropped per second.
If you put i50 stuff on a i60 sequence,10 new images have to be interpolated.
In FC you have no control on how those operations are performed.
rafael
