Activity › Forums › Apple Final Cut Pro Legacy › shooting 16:9 vs 4:3
Posted by Mati Kiin on May 25, 2006 at 3:55 pmQ: A producer friend suggested continuing to shoot mini-dv project in 4:3 even though final edit will be converted to 16:9 – does this make sense, or not?
Craig Alan replied 20 years, 4 months ago 4 Members · 3 Replies -
Todd Gillespie
May 25, 2006 at 4:47 pmNot really.
To get 4×3 footage to look like 16×9, you need to zoom in 15-25% which doesn’t look that good.
Especially if you are cutting in DV.Todd at UCSB
Television Production -
Enzo Tedeschi
May 25, 2006 at 9:10 pmHow much has already been shot? Finishing in 4×3 would give you consistency across all material. If you haven’t shot much so far, definitely go 16:9.
Todd’s right, though, you don’t want to do a blowup to 16:9 from 4:3 – would pillarboxing be an option for the 16:9 conversion?
Also, as a matter of interest – some countries (eg UK’s BBC) have found a compromise for their archival stuff which is in 4:3 – they blow it up slightly so that it is 14:9 aspect ratio. On a 16:9 screen it gives a small amount of pillarboxing, and crops a small amount off the top and bottom. The advantage is that it fills more screen than 4:3, and you don’t have to blow it up nearly as much.
Not suggesting this as an option – just as a matter of interest.
Enzo Tedeschi
____________________________
Editor
Sydney, Australia -
Craig Alan
May 26, 2006 at 6:32 pmDepends if your camcorders shoot in 16:9 native. If so, use 16:9, if not…
