Activity › Forums › Apple Final Cut Pro Legacy › Shootin with Sony PD-170, Audio buzz Removal with FCP/Soundtrack.
  • Shootin with Sony PD-170, Audio buzz Removal with FCP/Soundtrack.
    Posted by Rob Gee on January 2, 2006 at 3:40 am
    Hi, I shot interior documentary footage with this camera and an external Schoeps MK41 mic, going through a mixer, and into the XLR sockets on the camera. My sound guy didn’t hear any hisss or buzz (he was monitoring through his mixer), but I hear it clearly in post. I was not also monitoring through the camera, as I now realize I should have. It may have been the audio flaw in the Sony camera that I’ve heard about.
    Is there something I can do in FCP to remove the buzz and keep as much of my subject’s voice range as possible? He has a nice deep bass voice, if that helps. Thanks very much. – Rob
    David Bogie replied 20 years, 9 months ago 5 Members · 4 Replies
  • Bouncing Account needs new email address
    January 2, 2006 at 3:50 am
    If you have an earlier version than FCP 5, you need to use other software to remove this noise effectively.
    This is the kind of “continuous” noise that a program like Bias “SoundSoap” can help remove.
    https://www.kenstone.net/fcp_homepage/review_soundsoap.html
    Bias has recently released “SoundSoap 2”
    https://www.bias-inc.com/products/soundsoap/
    SoundSoap was retailing for about $50 (up to $80 just before the new “2” release).
    SoundSoap 2 is priced at about $100.
    If you have FCP5, there is a similar supplied filter that can do the job similar to SoundSoap.
  • Steve Connor
    January 2, 2006 at 9:07 am
    Soundtrack can do a remarkably good job of removing noise if it’s at a constant pitch, you should be able to maintain the bass tone of the voice as well – try it!
    Steve Connor
    Cardinal HD
    Please fill in your profile – it helps US to help YOU!
  • Ed Dooley
    January 2, 2006 at 1:33 pm
    And for a quick fix with one constant frequency you can use the 3 band EQ. Isolate the offending frequency
    by scrolling the freq bar up and down while the audio is playing and
    set it to -20db. If it’s mostly on one frequency, it shouldn’t hurt the overall audio. I just did it with a noisy lav,
    the buzz was at 8,940. I kept the band narrow and lowered that freq to -20, and it was a quick fix right in FCP.
    Ed
  • David Bogie
    January 2, 2006 at 9:57 pm
    Soundtrack Pro will do this job easily and quickly. It takes a bit of practice but study the seciton in the manual for PROCESSING. What you’re going to do is tell STP what you want filtered out by selecting a small portion of room tone. Then you apply that process to the entire clip. It’s scary magic.
    bogiesan
