Activity Forums Panasonic Cameras shoot in 720p release in 1080i workflow
  • shoot in 720p release in 1080i workflow
    Posted by M Brown on September 11, 2006 at 5:12 pm
    We have a client who wants his one hour porgram shot in 720p & released in 1080i. We have a couple of edit systems, one has a Kona II card and the other a black magic Decklink HD card.
    We also have another project that is about half 720p and half 1080i, but must be released in 1080i.
    Anyone suggest the most efficient workflow?
    Thx…mason
    Jay Roman replied 19 years, 7 months ago 4 Members · 3 Replies
  • Mactrix
    September 14, 2006 at 7:45 pm
    The freeware MPEGStreamclip does a wonderful format conversion.
    It works not only with MPEG clips but also with QuickTime movies.
    Open the QuickTime movies in MPEGStreamclip, choose ‘QuickTime
    Export’ from the ‘File’ menu and make your settings. There are
    various options for interlaced scaling, deinterlacing and chroma
    reinterlacing …
  • Shane Ross
    September 20, 2006 at 10:03 pm
    If you had the Kona 3 then you could upconvert the footage thru the card in realtime. But seeing that you are in the same boat as I, you will have to do it the harder way.
    Take your 720p sequence and copy it. Create a new sequence that is 1080i (uncompressed 8-bit if you are working with DVCPRO HD. It is an 8-bit codec) with the required framerate and paste your timeline into this one. Now resize the clips to fit the current sequence (Sequence Menu). It won’t show up as an option if you highlight transitions, so what I did was map the command to an F-key and highlighted several clips at a time then resized. It took a while, but worked. Then I hit RENDER. This took a while, but when done it was ready to be output to tape. OR….This just hit me…you can export a Quicktime Movie, self contained, and import that back into FCP, drop it into the 1080i sequence, resize it (one clip) and render. Yeah, that will save tons of time. Except that your graphics and text will look better if the original files were rendered at the higher resolution, rather than upconverting them.
    Also make sure you have plenty of room for the render.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jay Roman
    February 3, 2007 at 6:58 pm
    I have similar project where I have to upconvert from 720p/23.97 to 1080i/59.94 for SXSW festival. The final tape required format is HDCam. Steped thru Shane’s suggestion and all is well except for the picture isn’t full size. I know I’m missing something simple here.
    Jay Roman
