Shockmount for XHA1?
Posted by Than Baardson on October 7, 2009 at 2:58 amHey everyone,
Is there a way to attach a shockmount to the XHA1’s external mic terminal?
The hotshoe is reserved for my on-cam light and I’d rather not use the terminal directly with my NTG-1. Thanks,
-ThanRobert Kennedy replied 16 years, 11 months ago 3 Members · 5 Replies -
Jordan Wolf
October 8, 2009 at 7:42 am -
Than Baardson
October 8, 2009 at 4:46 pmVery true, I was wondering about after-market shockmounts. I’ve heard the stock one still transfers noise.
Jordan Wolf
October 9, 2009 at 6:24 amIf you are concerned about handling noise transferring to the mic from camera usage, you should hire a boom op/sound mixer. A shockmount will only alleviate the symptom (handling noise) whereas the actual problem is that the mic is still more-than-likely too far away from the source to truly be useful.
Wolf
Robert Kennedy
October 9, 2009 at 7:14 pmIf you would like you can split the shock-mount to allow it to hold both your light and microphone.
Here is a photo: https://images.buzzillions.com/images_products/00/41/cool-lux-md-3000-light-sound-bracket_875681_raw.jpg
Paired with a Rode SM-3 and a decent shortie XLR and you have a mic mounted on camera. The profile is rather high so don’t plan on running through the jungle with it or staying inconspicuous.
If you want to mount the microphone with a lower profile, we have had some success on JVC cameras replacing the noisy, inferior included shockmount with the top part of a rycote pistol grip setup. A little hardware skills and ingenuity will help you mount it with the rubber down.
Here is a photo:
https://coffeysound.com/product.php?productid=422&cat=0&page=2Of course I agree that this is no replacement for a skilled audio professional controlling mic placement.
Robert
CoffeySound.com
