Activity › Forums › Adobe After Effects › shiny eyeball
shiny eyeball
Posted by Dakota Joe on February 18, 2006 at 9:02 pmI created a big eyeball for a close-up in AE, but it doesn’t have the glossy look I want for an eyeball — is there a filter that can do this? Thanks.
Ryan Hill replied 20 years, 6 months ago 3 Members · 3 Replies -
Michael Szalapski
February 19, 2006 at 2:05 amI have had to recreate reflections before. The glossiness of an object is built with reflections.
You could try bevel on the eye a bit, but it’s more likely going to be adding in white bits (or actual footage screened) to create a good glossiness.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Dakota Joe
February 19, 2006 at 3:19 amThank you, O Greatly Not-So-Great One. What you said makes a lot of sense — I’ll try it!
Ryan Hill
February 20, 2006 at 4:05 pmGlue down a ping-pong ball, shoot it, then slather it in vaseline.
Apply difference matte between the two versions. I can’t say for sure how well that will work, but at least if you have to do it by hand you’ll know what you want it to look like.
