Activity › Forums › Adobe After Effects › Shiney text
Shiney text
Posted by Michael Calvino on September 7, 2005 at 11:07 pmNeed to make text look like gold
and so would like to shimmer some light across the surface….any ideas…
Roland R. kahlenberg replied 21 years ago 4 Members · 5 Replies -
Colin Braley
September 8, 2005 at 12:08 amFor the light shimmer across the surface you could try out CC Light Sweep as a quick and easy solution.
~Colin Braley -
September 8, 2005 at 12:45 amFor gold-like text, look at a post I made a few days ago that has a few Animation Preset Freebies. There’s a preset that creates a metallic texture. To put your alchemy thoughts to practice; switch on the Tint plugin to add color to the texture to turn it gold.
HTH
Roland Kahlenberg
broadcastGEMs
customizable animated backdrops with Adobe After project files -
Brandon
September 8, 2005 at 1:24 amI just created beatiful shiny gold text with 3d invigorator and just save the frame
September 8, 2005 at 1:50 amInvigorator does beautiful gold text and other bits. Unfortunately, it doesn’t access AE’s built-in Text Animation Presets. There’s good and bad either way you look at it.
Cheers
Roland Kahlenberg
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files
