Activity › Forums › Adobe After Effects › shine effect with plane as an emitter
  • shine effect with plane as an emitter
    Posted by John Wahoo on April 22, 2009 at 2:58 pm
    i found a video on the web that looked exactly like the shine effect from trapcode, besides that the light emitter does not seem to be a point, but more a plane, sending straight lightrays.
    here´s a link to the video. i´m talking about the plane with the round holes at the beginning.
    https://www.audiovisual.at/download/dccomics.mov
    I thought that trapcode shine only works with a point emitter, did i miss some settings, or what are your thoughts about doing this effect?
    thanks
    Kevin Camp replied 17 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    April 22, 2009 at 3:58 pm
    if you push the source point way off the screen, you’ll start to get that effect. you can do something similar with cc light burst too, and it has a halo alpha option which is a bit more like what these rays look like. you could do something similar with shine, but you’d need to create a different layer for the shine part that looked more like outlined circles rather than filled circles…
    for a quick setup, create a new white solid and add the checker board effect (it will be squares instead of circles, but this is a quick demo). make it 3d and rotate the x-axis -90 and position it so it seems like it’s on the floor.
    add a new adjustment layer and add shine or cc light burst. adjust y-position of the source point or center property to something like 3000 to move it way off the bottom of the screen.
    add a 3d camera and use the camera orbit and tracking tools to move around the scene to see how it reacts…
    obviously there is a fair amount of work to still be done, but i think this will get you close…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
