Activity › Forums › Apple Motion › shine behaviour – nasty outline on text
  • shine behaviour – nasty outline on text
    Posted by Phil Sheldon on January 5, 2016 at 10:26 am
    Hi all
    got an issue with the shine behaviour putting a nasty outline on some text. any ideas how to remove it? i’ve tried removing outlines in the bahaviour but it just wont go. images below hopefully!
    the top one shows the text before the behaviour starts, the other during
    any help most appreciated
    Phil
    Bret Williams replied 10 years, 8 months ago 3 Members · 3 Replies
  • Robin S. kurz
    January 6, 2016 at 10:56 am
    [phil sheldon] “putting a nasty outline on some text”
    That actually appears to be a weird bug in the behavior. What you’re seeing is the initial “Blur” state that is subsequently animated. For some reason, even when set to ZERO, it is still applying an ever so small amount of blur that peeks out from behind, which it of course shouldn’t. Unfortunately there’s no easy solution that I can find.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Phil Sheldon
    January 6, 2016 at 4:01 pm
    wow – i think this is the first time it isn’t me doing something stupid!!
    thanks loads for having a look for me, changing the font colour has mostly hidden it. not ideal but will have to do
    thanks for your help
    Phil
  • Bret Williams
    January 7, 2016 at 10:08 pm
    Animate the transparency/mix of the effect?
