Activity Forums Apple Final Cut Pro Shifting retiming starting point
  • Shifting retiming starting point
    Posted by Hans Douma on June 17, 2015 at 8:32 pm
    Hi all,
    A question about retiming in FCPX and then in particular changing the variable retiming. Consider the following:
    I have applied retiming to part of a clip using the Range Selection tool and that works fine with a build in and build out. Now I want to shift the beginning of the retiming to start earlier or later and I cannot find how to do that. E.g. if I want to start the slow motion later in the clip, I would expect I could drag the handle at the end of the 100% part to the right. But when I do that, it will change the speed at the beginning from 100% to less than 100%. That is not what I want. I want the start of the slow motion to shift to the right. The only way I can see now is to re-select the range with the variable speed, reset the timer and select the new part of the clip and re-apply the timer. It would be so much easier if I could just drag the start of the slow motion to change the starting point. There must be a way to do this, I just can’t find it.
    Any ideas ?
    Hans Douma replied 11 years, 3 months ago 2 Members · 2 Replies
  • Charlie Austin
    June 17, 2015 at 10:28 pm
    Double click the center of the retiming transition… little pop up will appear and you can choose to move the edit point by dragging the little film frame handle…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Hans Douma
    June 18, 2015 at 11:25 am
    Brilliant. Thanks very much
