Activity Forums Adobe After Effects Shifting masks
  • Shifting masks
    Posted by Ken Ecker on February 7, 2008 at 10:32 pm
    I apologize for the stupid question, I’ve searched quite bit…
    I’ve corner pinned a still (which is in the comp as a 3d layer) into an area. I now need to mask part of the still once it has been pinned. Once I draw the mask, AE applies the mask to the image’s position before it was corner pinned (and the mask is therefore off). I tried precompsing, but no dice. What am I missing?
    Ken.
    Ken Ecker replied 18 years, 7 months ago 2 Members · 3 Replies
  • Ken Ecker
    February 7, 2008 at 10:43 pm
    Thanks for the help Dave.
    My issue is, I need to corner pin before masking, as the mask is reasonably intricate.
    I’m kind of stuck trying to think of a workaround…
    any thoughts are appreciated.
    Ken.
  • Darby Edelen
    February 7, 2008 at 10:45 pm
    When you pre-composed the layer, did you select “Move All Attributes”? You need the corner pin effect to be applied inside of the pre-comp, then mask the pre-comp in its parent comp.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Ken Ecker
    February 7, 2008 at 10:48 pm
    I thought I did select ‘move all atributes’, but just tried it again and it worked perfectly.
    Thanks so much Darby and Dave for the quick responses.
    Ken.
