Activity Forums Media 100 Shifting M100 application file to another hard drive
  • Shifting M100 application file to another hard drive
    Posted by Bruce Mcpherson on August 18, 2010 at 12:54 pm
    Hi All,
    I am wondering how to shift my M100 application file off a older IDE drive to a newer SATA drive in my G5.When I do this I get a message saying that it cannot find a quicktime file it needs.
    My app came as a download direct from M100 and I dont have a copy of the data on a DVD (silly of me).
    Are you able to point me in the right direction 🙂
    Cheers Bruce
    Bruce Mcpherson replied 16 years, 1 month ago 2 Members · 4 Replies
  • Floh Peters
    August 18, 2010 at 6:35 pm
    The easiest way would be to re-download the installer and reinstall. Otherwise you need to start searching for the missing files on your old HD.
  • Bruce Mcpherson
    August 19, 2010 at 11:57 am
    Thanks Floh, Trouble is that I dont have an “install disc” as mine was a download install.I will get in touch with M100 for a new download.
    ( My systen is sited on a IDE drive in a FW800 external drive and I want to change to a bigger SATA drive internally in the G5, and the app doesnt like being resited 🙁
    Cheers
    Bruce
  • Floh Peters
    August 19, 2010 at 8:03 pm
    On the Media 100 website are various older versions available for download (as long as you have the matching encryption code). So simply re-download your version and install it.
  • Bruce Mcpherson
    August 20, 2010 at 2:05 am
    Yes, Thanks Floh, allready done that. The way it works is that the nice folk at M100 have set these downloads up with a trial version startup so you can finish that urgent project you were working on before the drive went sideways, – giving you breathing space to sort out the unlock codes – this is a lifesaver when the pressure is on……
    Thanks again for your help
    Bruce
