Activity Forums Boris FX shifting keyframe values
  • shifting keyframe values
    Posted by Peter Burn on July 25, 2009 at 7:43 am
    Is there a setting to prevent changes to key frame #5 affecting #4 and #6? I change the xyz and position after placing the title and holding for 4 seconds then it should go away but the disappearing, spinning and tumbling commences at frame #4?
    Peter Burn
    Peter Mcauley replied 17 years, 1 month ago 2 Members · 1 Reply
  • Peter Mcauley
    July 27, 2009 at 1:06 pm
    Hi Peter,
    It’s not exactly clear to me what you are trying to accomplish – if you would like to send me a setting and explain the effect that you are trying to create then I’ll take a look at it and send a modified project back to you. You can send that to me at peterm@borisfx.com.
    Cheers,
    Peter.
