Activity Forums Avid Media Composer Shifting issue with Quicktime Reference!!!!!
  • Shifting issue with Quicktime Reference!!!!!
    Posted by Wayne M on August 16, 2007 at 7:07 pm
    I have an issue in which whenever a graphic with an alpha comes on, the screen seems to shrink a bit and gets a little darker.
    This is only seen when I create a Quicktime Reference.
    It doesn’t matter what it is…It’s when anything is keyed over a background. It can be footage, an animation (like a jumpback or AE MOV) or even a still image (like a PSD ot PNG.)
    This is a link to a wmv I made showing this issue. HELP!!!!!
    https://www.imageresourcesgroup.com/IRG/AVIDISSUE.wmv
    Mark Angolia replied 19 years ago 4 Members · 3 Replies
  • Jon Zanone
    August 17, 2007 at 10:58 am
    Do 1 of 2 things.
    -Mixdown your sequence (or just the portion with the key)
    -Lay a submaster effect on the clip you want to key, and step into it. Lay your graphic down. Render to play.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Leisa Bolles
    August 20, 2007 at 5:29 pm
    Are you mixing a DV resolution with a non DV resolution (ie Dv 25 and 1:1?) The shift can be caused when you mix the two. Also what is your Effect Aperture set to in General settings (DV 720×480 or NTSC 720×486?) If you have your effect aperture set to DV and then create a graphic at 1:1 which is 720×486 that causes a shift because of the 6 scan line difference. I have had this happen when editing footage at DV25 and importing a Jumpback with the import resolution set to 1:1. If you are using DV25 footage I suggest using DV50 for imports and other graphic elements and setting your aperture to DV.
  • Mark Angolia
    September 7, 2007 at 7:25 pm
    I worked with Avid for over 2 years on this bug. Not until I spoke the Avid’s general manager at NAB did the issue get fixed 2 weeks later.
    You must be trying to mix 1:1 titles with DV footage.
    They fixed their DV codec so you need to make sure that is checked when you do an export.
    Hope that helps.
    Mark
