Activity Forums Apple Final Cut Pro Legacy Shift Field and VHS enhance
  • Shift Field and VHS enhance
    Posted by Steve Tamou on March 19, 2012 at 4:05 am
    I am getting an automatic shift field filter (-1) when I put a video clip that was captured to FCP from a VHS tape in the timeline. Does anyone know if I should keep it there or delete the filter? And what techniques can I use to enhance the VHS video. I am incorperating it in a HD video. Thank You.
    Steve Tamou replied 14 years, 6 months ago 2 Members · 2 Replies
  • David Roth weiss
    March 19, 2012 at 5:21 am
    Since most SD is lower field first, and since all HD is upper field first, the Shift Field filter is automatically applied by FCP when you drop SD clips onto an HD timeline. So, it’s most likely correct. If you monitor on a real video monitor, not a computer monitor, you will be able to see the difference in your video when you toggle the filter on and off on a clip.
    As far as enhancing VHS blown-up to HD, the only thing that will help is a noise reduction plugin like Neat Video (https://www.neatvideo.com/), and good color correction.
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    http://www.ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Steve Tamou
    March 19, 2012 at 5:30 am
    Thank you sir. I will look into the Neat Video plug-in.
