Activity › Forums › Apple Final Cut Pro Legacy › SHIFT-F failure
  • SHIFT-F failure
    Posted by Kimberly on May 11, 2005 at 12:44 am
    Working in FCP HD 4.5, various G5s, OSX 10.3.9 on a documentary series…
    In doing our footage counts the SHIFT-F shortcut to reveal a clip from the timeline in the browser (to determine which bin the clip is from) isn’t working for us.
    We’ve tried all basic troubleshooting (track auto-select, window activation, etc) and still can’t figure it out. In tests, SHIFT-F to holds up fine in smaller projects but fails (on various systems) when used on the hour-long episode.
    Any known bugs, workarounds, or suggestions?
    David Bogie replied 21 years, 4 months ago 6 Members · 6 Replies
  • Jerry Hofmann
    May 11, 2005 at 1:57 am
    How many clips are in the browser with these longer projects? Are the clips subclips or are they master clips? I can’t reproduce this with a project file that contains maybe 200 clips or so… it’s working here.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bryan Shelton
    May 11, 2005 at 2:57 am
    From what you wrote I am assuming that you are moving masterclips and timelines back and forth between various projects.
    If you move a timeline from one project into another all the clips in the timeline become independent. Which disables SHIFT-F but not OPT-APPLE-F or just plain F.
    I have had this problem occur on multiple occasions as I try to avoid the ridiculously long save times that FCP needs when working with larger project files. What I generally do is create a new bin, use OPT-APPLE-F, and drag the clip from the viewer into the new bin.
    -b
  • Mark Raudonis
    May 11, 2005 at 3:46 am
    It sounds like your project is missing the folder from which the clip came. If that’s the case, then shift F will not work. FCP can’t find a folder that doesn’t exist in that project. If you want the match function to open the folder from where the clip came from, that folder must be in the current open project.
    mark
  • Les Kaye
    May 11, 2005 at 4:22 am
    Can you create a new folder with the same name as the original?
  • Jerry Hofmann
    May 11, 2005 at 1:00 pm
    As has been suggested, you can, but it won’t find a browser clip that’s once been deleted. Even reimporting it won’t make the shift+f command show the new reference…
    Jerry
  • David Bogie
    May 11, 2005 at 2:20 pm
    Looking at the other post (or posts),Kimberly seems to be posting about a series of problems related to not quite understanding FCP’s weird family of Browser items: independent clips, subclips and master clips. Time to RTFM.
    bogiesan
