Activity Forums Adobe Premiere Pro Shift A equivalent
  • Shift A equivalent
    Posted by Steve Cohen on July 4, 2016 at 7:16 pm
    I’m making the switch from FCP 7 to Adobe CC and I’m picking it up pretty quickly.
    There are some things that I find really useful in FCP and just can’t figure out how to do in Premier.
    The one I’m battling now is marking the in and out points of a clip in the timeline.
    FCP is Shift +A.
    I can’t figure it out for Premier. Even if I switch to the FCP 7 keyboard layout it doesn’t work.
    Is this one of those things that just won’t happen like Insert with default transition.
    Steve
    Steve Cohen
    David Roth weiss replied 10 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Ann Bens
    July 4, 2016 at 8:22 pm
    Select clip and hit / ?
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Steve Cohen
    July 4, 2016 at 9:13 pm
    Thank you Ann.
    That’s helpful.
    Steve Cohen
  • Alex Hawkins
    July 5, 2016 at 11:11 pm
    Also Steve there are quite a few actions within PPro that don’t have a default keyboard shortcut attached to them. If you’re using the FCP7 layout then Trim & Ripple Trim next and previous edits to playhead would be the first ones I’d map to shortcuts.
    Cheers.
    Alex Hawkins
    Canberra, Australia
  • Steven Cohen
    July 5, 2016 at 11:55 pm
    Thank you Alex, but I’m using the standard keyboard layout.
    I want to be a Premiere editor, not a Final Cut Pro editor working on Premier.
    Steve.
  • Andrew Kimery
    July 6, 2016 at 12:22 am
    [Steven Cohen] “I want to be a Premiere editor, not a Final Cut Pro editor working on Premier.”
    From what I recall PPro’s default layout is pretty barren. It’s been a while since I used it though so maybe it’s gotten better. Don’t be afraid to create your own custom keyboard though, it’s why that feature is there. 😉
  • Steven Cohen
    July 6, 2016 at 12:28 am
    I am as I find things I need.
    Steve.
  • David Roth weiss
    July 11, 2016 at 3:18 pm
    Get yourself a Premiere keyboard.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
