Activity Forums Blackmagic Design Fusion Sherlock balance effect
  • Sherlock balance effect
    Posted by Leonhard Wolf on July 8, 2017 at 11:47 am
    Hi everyone,
    I recently watched Sherlock season 4 and noticed this cool effect: Sherlock throws a bag and guesses the weight in slow motion. To show this there is a text animated to go from 1 to 1000 and back down again.
    I was wondering how you could achieve that in Fusion. Sadly I can’t seem to figure out how to animate the text itself. Would you have to use expressions or Python?
    I would be happy for suggestions to pull this effect off!
    Mainboard: Asus Maximus Ranger VII
    CPU: Intel i7-4790k (not overclocked)
    GPU: AMD Radeon HD 6870
    RAM: 8GB
    Soundcard: Avid Eleven Rack
    HDD: 2TB
    OS: Windows 10 Home, 64bit
    Leonhard Wolf replied 9 years, 1 month ago 2 Members · 2 Replies
  • Simon Ubsdell
    July 26, 2017 at 10:56 am
    In the Text tool, right-click on the Styled Text box, select Expression and enter the following expression:
    Text(iif(time<50, max(1, time*20), max(1, 2000-time*20)))
    This will count up from 1-1000 over 50 frames and then down from 1000-1 over the next 50 frames.
    There are many different ways of doing this depending on what you want to achieve.
    You could control it in a different way by simply adding an expression that links the Text to an animated parameter on another tool. So for example, you could animate the Size of a Transform tool (it doesn’t even need to be connected to anything) from 1-1000 and then instead of the above expression in the Styled text field you could use the following:
    Text(Xf.Size)
    (To make that work rename your Transform tool to “Xf”.)
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Leonhard Wolf
    July 28, 2017 at 10:47 am
    Thanks for your suggestion.
    It worked for me!
    RAM: 8GB
    HDD: 2TB
