Activity Forums Apple Final Cut Pro Legacy SheerVideo interlaced
  • SheerVideo interlaced
    Posted by Jan Van den bossche on November 7, 2009 at 2:24 pm
    I’m using the try out of Sheervideo on MacPro. When I export from After Effects CS4 with Sheer 8bit 422 with standard option settings and play the quicktime file in FCP5 in a sequence with the same Sheersettings, then I see on the computer screen “stripes” in the image. Like there is something wrong with the fields (I use upper fields first in after effects export and also in the FCP sequence). But on a tv monitor everything is ok. Am I doing something wrong ?
    thank you
    Jan Van den Bossche
    Rafael Amador replied 16 years, 10 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 7, 2009 at 3:46 pm
    Hi Jan,
    You can only check interlaced issues in an interlaced monitor or TV.
    If its looks well in the TV, don’t worry about the computer.
    If you want the movie to look well in the computer, deinterlace.
    rafael
    http://www.nagavideo.com
  • Jan Van den bossche
    November 7, 2009 at 3:51 pm
    thanks Rafael, the most important thing is that it looks good on a PAL tv, but it’s still kinda strange.
    I figured out that it’s only with the graphics, not with video images underneath it, so maybe it’s something with the motion blur on the graphic layers in CS4.
    Jan Van den Bossche
  • Rafael Amador
    November 7, 2009 at 3:56 pm
    Did you “Interpret” the footage as interlaced in AE?
    rafael
