Activity › Forums › Maxon Cinema 4D › Shattering text – moving particles to other text layer
  • Adam Trachtenberg
    August 5, 2008 at 9:55 pm
    The example was done with pBlurp. That’s what you’re missing.
  • Caleb Thomas
    August 5, 2008 at 11:31 pm
    I’m going to have to check the manual to see which one that is.
  • Caleb Thomas
    August 5, 2008 at 11:54 pm
    Thanks Adam, you are exactly right! Thanks man, that’s what I needed.
  • Caleb Thomas
    August 15, 2008 at 9:37 pm
    I got it to work right with pblurp, sort of. It functions but after the text leaves the first line of text it falls towards the other and then stops at a certain point and starts from the bottom as you can see here:
    https://www.grabup.com/uploads/36f6f62e4dd864383da5119c6f9f077c.png
    If I change -Y to +Y or anything else I always get a variation of this. I can post an image of it in a little while. It’s not in front of me right now.
