Activity › Forums › Boris FX › shattered text in motion
  • shattered text in motion
    Posted by Glenn Grant on June 27, 2008 at 6:36 pm
    I am trying to apply the BCC 5 3D shatter effect to some text in a 2D motion 3 project. I have an arrow coming down it hits the text and the text shatters. The problem is the shattered pieces don’t fly out of the Motion scaling box that surrounds the text. This is the box that you grab to resize or move the text around.
    Does anyone know I I can scale the box so all the shattered pieces are seen, with out scaling the text and pieces inside the box.
    Glenn Grant replied 18 years, 3 months ago 2 Members · 2 Replies
  • Peter Mcauley
    June 27, 2008 at 7:14 pm
    You need to precomp or nest the text so that it can provide the shatter filter a full frame size bounding box and thereby shatter the pieces over the full frame of the composite.
    I hope this helps.
    Peter.
  • Glenn Grant
    June 28, 2008 at 3:01 am
    Thanks Peter. I ended up sending two files to FCP and applied the shatter effect there. I will try your suggestion also it sounds like a better idea the what I ended up doing.
