Activity Forums Adobe After Effects Shatter question
  • Shatter question
    Posted by Grayson Sedory on December 4, 2008 at 5:43 am
    Hi, Im actually doing and intro to a project with a brick wall, I’d like to use shatter to explode the brick wall and start the first scene right through the wall. I’m having a problem when I apply shatter it applys it to all the layers, what the best way to apply shatter to a layer toward the end of the timeline and have another source behind it? I’m self-taught with After Effects so please keep it simple, thanks
    Grayson Sedory replied 17 years, 9 months ago 3 Members · 3 Replies
  • Travis Kelly
    December 4, 2008 at 2:15 pm
    Not sure what you’re doing wrong, but I just did a test and it worked fine, take the picture of the brick wall, I put a blank red solid under it, dropped the shatter effect on the brick wall layer, and it works perfectly, the wall shatters, and the red solid is underneath. Hope that helps
  • David Bogie
    December 4, 2008 at 7:42 pm
    [Grayson Sedory] ” I’m having a problem when I apply shatter it applys it to all the layers, what the best way to apply shatter to a layer toward the end of the timeline and have another source behind it? “
    Shatter is highly advanced because of its complexity and dozens of hidden parameters. But Shatter can only be applied to a single layer at a time so I’m assuming you are either precomposing improperly or trying to use Shatter on all layers.
    Shatter starts affecting pieces immediately unless you keyframe the size of the force sphere. Do not attempt to keyframe the Strength parameter. It does not control which pieces begin to move, it just controls how fast they move. There is extensive SHatter help in the AE Effects documentation but you sort of have to search for it.
    Here’s some help from the author of the effect, Brian Maffitt: The physics of Shatter are applied to any piece that has permission to go. You give a piece permission to go by touching it with the Force Sphere. You can movie it around or you can change the diameter of the sphere. If you move it around, you get a line of pieces flying off the layer. if you change the diameter, you get a shockwave effect. Remember there are two Force Spheres.
    bogiesan
  • Grayson Sedory
    December 4, 2008 at 11:21 pm
    Hi, I greatly appreciate both your responses, I think my difficulty has to do with something simple to the trained AE eye however my project is due next thursday and this is just a tiny aspect of it that is neccessary only to my creative aspirations. That being said I came up with a round about solution. I completed and rendered out the comp with the brick wall exploding and put that back into another comp and used a luma key to key out the black and put the background footage under it. I know it was a somewhat unconventional way to come up with the solution but it worked just fine. I’m a student at Boston College and I’m taking a course focusing on After Effects next semester where I’m sure i’ll be able to fill in my AE gaps a bit. Thanks again.
    – Grayson
