Activity Forums Zaxwerks Shatter & Invigorator Pro
  • Shatter & Invigorator Pro
    Posted by Chadman on August 16, 2005 at 12:02 pm
    Greetings all
    I am setting up a 3d Logo using an illustrator vector file. I wish to use the illustrator file as a custom shatter map as well. But for some reason shatter always stretches the size of the file to meet the size of the composition.
    As a result, the shatter does not work correctly. I tried to re-save the illustrator file as the same size as the composition, but it still zooms in on the item within.
    Is there any way I can set it, either within After Effects, or using Illustrator so that the file is not stretched and the shatter then works properly.
    Many thanks in advance
    Chadman replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
